In case of custom post types you can display the taxonomy in the category spot, if that is what you want to do
– https://forum.tagdiv.com/custom-post-type-support/
Those are all the settings the theme has for custom post types, most of the settings are created for categories so custom post types don’t have many options.
In blocks or grids you can display CPTs but they cannot be filtered by taxonomy
– https://forum.tagdiv.com/block-settings-tutorial/
Hi Simion C.
I’ve understood the fact that CPTs can’t be filtered by custom taxonomies in blocks or grids. That said, is there an existing hook or anything that could allow me to add some custom code (without altering future updates) to add filters by custom taxonomies on CPTs in grids/blocks?
Best regards
@Biznetaucoeur The blocks/grids are not supposed to handle taxonomies, so there is no functionality to support them. Default categories and tags can be used to filter/sort the posts but not taxonomies. This may change in the future, as this request becomes more popular. Sorry for any inconvenience.
Hi Simion,
Thanks for your answer, I’ll probably “bypass” this functionality using a shortcode to generate similar blocks/grids then.
