How to get A ratings at speed test
For my site : https://anonymster.com/
I performed a couple of optimization recommended in the guide i could find on the forum and documentation.
However i am left with this rating : https://tools.pingdom.com/#!/cpAEXx/anonymster.com
Combine external CSS
Parallelize downloads across hostnames
Minimize request size
Remove query strings from static resources
Could you please help to fix those last 4 blocking points ?
thx
We recommend using our official page speed guide: https://forum.tagdiv.com/how-to-make-the-site-faster/
As a note on speedbooster: https://forum.tagdiv.com/topic/tinymce-advanced-and-other-various-disabling-speed-boster/
You can also test a post on your site with GTMetrix.com which will show you examples of HOW to fix things to optimize your site. My old old tutorial on the ‘best of tutorials’ section might be helpful too, but long read.
Hello Chris,
would you be able to provide consulting to help fix the speed score ?
I have a bit of budget for it if you can tell me how to contact you.
thx
