Hi, I Just started publishing my blogs/articles, and I’m facing issues as its a totally different from Elementor. I already checked YouTube videos but did not get the idea. Is there any blog or step-by-step detail for writers? I really appreciate your help, as we are new to this page builder, so not sure how to start it because there are a lot of functions when you start the post but i cant find where should i write my blog body etc you know what I’m trying to say.
Thank You
The tagDiv Composer is our page builder and it can be used for building pages and cloud templates, but not for creating posts. For this, you’ll need to use Gutenberg or a classic editor.
Using tagDiv Composer, you can build/edit the single post template (the layout of the posts).
Here is a video that will show you how to use the builder to create a website from scratch https://www.youtube.com/watch?v=SoGQ0d5kIBg to do this you’ll need to already have the posts.
Also, on our channel https://www.youtube.com/channel/UCOT1RiNysIPCTPSnVZskwtQ, you can find more videos that can help you and documentation https://forum.tagdiv.com/newspaper-theme-documentation/ and you can ask us here on the forum or email if you have any questions.
