How to setting website Default PRO
Hello support,
I have installed prebuilt website – Default PRO then i viewed it on localhost, it showed content as attached image, link: https://imgur.com/a/Qn0BxSm
Pls help me set up to view website full as Default PRO.
Vunt
Hello Vunt!
Unfortunately, you can not edit with the tagdiv Composer the blog page generated by WordPress. Apply these changes: https://app.screencast.com/rd5HXhCY5MHne
When you access an article, it should be the single post template from the Default pro demo. You can upload another single cloud template from the Cloud Library to your posts for more customization options.
More documentation about the cloud templates is here:
– https://forum.tagdiv.com/cloud-library-templates/
– https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
– https://forum.tagdiv.com/cloud-library-category-templates/
About pages here: https://forum.tagdiv.com/page-templates-2/ -> https://forum.tagdiv.com/homepage-how-to-build-and-set-it/
Check out this video about how to create a website from scratch: https://www.youtube.com/watch?v=SoGQ0d5kIBg
