How to update theme if using child theme or if not using.
hey guys, thanks for the theme and support you provide. I have queries, please inform/guide me
1. how to update theme if using child theme
2. how to update theme if not using child theme. using theme out of the box.
3. if using child theme for my website. where to import the dummy data. either in the main theme or in child theme.
Hello harish.bhathee,
First of all, I will thank you for your interests in our theme and for your appreciations! Before I answer your questions, let’s clarify what exactly is Child Theme and how it will be used on WordPress platform. For this, you should read this document here -> https://codex.wordpress.org/Child_Themes
1,2)The theme can be updated in the same way if you will use the child theme, according to our documentation here -> https://forum.tagdiv.com/how-to-update-the-theme-2/
3)The dummy data can be imported in the same way if you will use the child theme. Read here -> https://forum.tagdiv.com/installing-demos/ Also, for more information about our Child Theme, please check here -> https://forum.tagdiv.com/the-child-theme-support-tutorial/
Hope this helps!
