Infinite load problem
I’m having a problem with the infinite load on my site. It doesn’t always load the images of the ‘related articles’ underneath the main blog post. Moreover, it often cuts off the blog posts half way through an article as you’re scrolling down. However, sometimes the posts load perfectly. It’s very temperamental.
Here’s a video of what I mean:https://www.loom.com/share/af03adbefadb461bab634f3beea1b800
At 0.40 secs you can the infinite load plays up. Here, the related images are cut off as you scroll down, but as mentioned, sometimes it cuts off half of the blog post! You can’t always replicate the issue straight away, but it will eventually happen if you click through different blog posts.
Any help would be much appreciated.
Hope that all makes sense.
The problem comes from your website’s page speed, or some external factors like the internet speed, that’s why maybe the images are not loading so fast.
We recommend using the WP Super Cache plugin with this configuration: https://forum.tagdiv.com/cache-plugin-install-and-configure
Our developers are working a lot to improve the page speed in every update.
So, please make sure you use the latest update of the theme and plugins because it may help you for your page speed. First of all, please make sure you have a backup done and then you can update the theme and the TagDiv plugins also.
I recommend you to make a backup and update plugins and the theme via file transfer, so that you don’t face any error: https://forum.tagdiv.com/how-to-update-the-theme-2/
Also, to increase the page speed you can check these similar topics for more solutions:
– https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
– https://forum.tagdiv.com/topic/score-100100-pagespeed-with-newspaper-wordpress-theme/
– https://developers.google.com/speed/docs/insights/v5/about
– https://www.youtube.com/watch?v=tnkVapqhIHc
Please note that page speed is not covered by the support team: https://forum.tagdiv.com/newspaper-theme-support/
