Instagram problem
Hi i have problem with instagram post on foother.
I dont have “Instagram Account Acces Configuration” in admin panel wordpress newspapper theme.
https://ibb.co/55wjXnv
Login is correctly.
This https://forum.tagdiv.com/instagram-widget/ not help.
Please help
Hello !
That option is available only from Newspaper 10 and we currently are at Newspaper 10.2.
In order to update please follow our tutorial here: https://forum.tagdiv.com/how-to-update-the-theme-2/
Will I lose my block layout after deleting the template? Will I have to create the template homepage from demo again?
I don’t want to lose the entire layout and homepage when updating. It took me some time.
https://imgur.com/a/mY6AySe
Hello !
If you follow carefully all the steps nothing will be lost because all the data is stored in the database not in the theme files. Please make sure to update the Newspaper Theme and activate the plugins after.
Please note that we answer the topics from Latest to Newest Monday – Friday from 08:00AM to 05:00PM GMT+2 So multiple replies to your topic will only make us to get harder to your topic.
Where is on 10.3 ACTIVE BUTTON for INSTAGRAM ??
i click CONNECT on AP wordpress INSTA and have error:
https://imgur.com/a/E3o0VNd
Hello !
Please note that for this you have a second method to try if the original option is not working. Click here: https://www.screencast.com/t/Ac7WGBri8v as you can see you can choose the second option.
I hope this was helpful !
