Hi Tagdiv,
Please help me out i cannot fully install the demo
it say’s : ajax problem. cannot connect to the server it may be due to a misconfiguration
on the server
Unfortunately this error could come from a big number of problems. I believe it happens due to a server configuration which is not responding, it could be due to a delay or it could also be a temporary issue so you can try this a few times and if you still get this error please contact your host provider and let him know about this, ask them to unblock our demo in order to retrieve the theme data. It could also happen due to your wp install or other plugins might also cause this. Also make sure that your permission for the upload folder are set correct. You can check this by trying to upload an image in media library. If the process succeeds then the permission are ok. If not you can use the c-panel to change permissions (set them to 777) or if you do not have access to the cpanel, please contact your hosting provider.
Also make sure you meet the requirements for newspaper: https://forum.tagdiv.com/requirements-for-newspaper/
If you still cannot install the demo, please send an email at contact@tagdiv.com and provide wp-admin so we can take a look. Please also provide a link to this topic.
Hi thanks for you response.
Upon checking the my WP config setting
I haven’t seen the WP memory limit (define( ‘WP_MEMORY_LIMIT’, ’64M’ )
define(‘WP_DEBUG’, false);
/* That’s all, stop editing! Happy blogging. */
/** Absolute path to the WordPress directory. */
if ( !defined(‘ABSPATH’) )
define(‘ABSPATH’, dirname(__FILE__) . ‘/’);
/** Sets up WordPress vars and included files. */
require_once(ABSPATH . ‘wp-settings.php’);
My question is how can i edit it to include the WP memory limit?
thanks
You can define the memory limit in the wp-config file. Please follow this guide to do it and increase the other parameters as well: https://forum.tagdiv.com/system-status-parameters-guide/
Please tell me how can i import this demo
http://demo.tagdiv.com/newspaper_blog_health/
Please response me fast…
In order to have access to that demo, you need to have the latest version of newspaper (version 7). Please update your theme by following this guide: https://forum.tagdiv.com/how-to-update-the-theme-2/ and make sure you also update all your plugins that come with the theme: (visual composer and social counter)
Then you can install the demo from the theme panel demos section.
Thank you so much…
I successfully activated that demo..
But i have one problem….
Post images are not showing ( attached link )
