intallation problem..
While i am installing newspaper 8.7, while upload the theme;
i see this message on browser;
“The link you followed has expired.
Please try again.”
Just had the same problem. Check out https://forum.tagdiv.com/system-status-parameters-guide/ – doing the wp-config.php edits fixed me.
thanks tensiond,
i try but i have same response 🙁
i work localhost, php 7.0.19 with MAMP.
HI,
Be sure to increase the max upload size parameter, this will affect the upload capability of WordPress. The theme file is around 10MB
– https://www.screencast.com/t/CwoHIgHbtM
Upload this file only not the whole theme package. These are the theme install guides
– https://forum.tagdiv.com/install-via-wordpress/
– https://forum.tagdiv.com/install-via-ftp/
The FTP method is the most recommended install method in general. If you use a local development environment you could simply paste the theme file in the WordPress themes folder, then activate it.
