Hello I have updated to the last vertion of Newspaper template, and i start having conflict between tagdiv cloud, and the last updated elementor Pro purchased.
I have critical error in the admin panel once i activate both, but i desactivate one of them, the admin page works, but the website is messy.
Do you have any solution to that issue ? can you also share with me the previous version of Newpaper template to test if there is the issue ?
The theme is not compatible with Elementor, especially if you’re using cloud templates. Additionally, it’s not recommended to use two page builders on a website, especially on the same page. You’ll need to choose which of the two plugins you want to use and rebuild your pages accordingly.
Ok thanks
And can you please send me the last version of the full template of newspaper witht Tag div plugins ?
You can download it from Themeforest https://forum.tagdiv.com/how-to-update-the-theme-2/
I have entered the licence key in the theme.
Once I enter the theme key and register the theme, it says that it is registered, but once i come back it says that it is not registered.
Thanks for your support
I’ve responded to your topic https://forum.tagdiv.com/topic/issue-to-validate-licence-template-newspaper/#post-504463
