hello every one,
in some articles there is a problem with images and links
you can see it here:
https://www.mag24.gr/tin-paraskevi-o-rous-sti-chora-ti-synavlia-anoigoun-oi-revma/
You can’t copy text, you can’t open an a link, you can’t open a photo.
Has anyone had a similar problem?
thanks!
Hello @akisloukas !
I can see that you get a 403 error, that’s why the image is not opening at the first click. It’s possible to be from the firewall or security module which blocks the admin-ajax.php request, which usually displays a 403 or 404 error.
If you don’t use a security plugin, please ask your host about this, maybe you have a security module that blocks this.
If you use a plugin like Wordfence please set it in learning mode.
Also, if you are using Cloudflare, please make sure that is set as in our guide https://forum.tagdiv.com/cloudflare-cdn/, you need to disable the Rocket Loader.
Examine some other potential interfering factors: https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
Make a test and deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
Let me know the results!
