Issue with header builder when site is served through AWS cloudfront CDN
My website is served through the Amazon cloudfront CDN. When I select a header template to import and run the import, it isn’t allowing a lot of the assets for the header to be downloaded so therefore it fails to properly import the header template and I can’t use it. For Amazon Cloudfront CDN I need to whitelist any cookies or HTTP headers. Are there any HTTP headers that I need to whitelist in cloudfront to make this work so they pass through to my origin server? Or any cookies I need to whitelist? Or IP addresses I need to whitelist in our web access firewall which monitors our website’s traffic?
Please make sure that you configured the Cloudflare (CDN) link in our quid -> https://forum.tagdiv.com/cloudflare-cdn/
Also please make sure that the theme system status is configured as mentioned in the requirements guide. Please follow the guide carefully
If you are using child theme, please deactivate it and try again.
