Lazy imagen problem
My website elpoderdelandroideverde.com never had lazy imagen effect only sometimes. Why? If i had activated that funtion on newspaper theme.
Hello Elevas32,
I have checked your website and it seems to work as properly. The lazy image loading seems to come from your end, your customizations, sorry! Check your hosting provider server to have the minimum resources, like this -> https://forum.tagdiv.com/requirements-for-newspaper/ Also, we have a guide for speed optimization, like this -> https://forum.tagdiv.com/how-to-make-the-site-faster/ Notice that all of these steps you should make it yourself because we cannot provide custom work and if you are not an advanced user and if you are not aware of the steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
Hi, Doesnt Word On Mobiles, always works on Desktops but sometimes works on mobile.
And this codec on funtion.php doesnt work too 🙁 add_filter( ‘jpeg_quality’, create_function(”, ‘return 50;’ ) );
Hi Elevas32,
Please notice that the speed of your website depends on how well your site is optimized. Notice that is not a simple task and if you do not have any experience in this regard you will do not bring good results for the theme. Also, notice that we have a speed optimization tutorial but this is addressed only to advanced users.
Please keep in mind that at the moment, we cannot provide optimization services because this task involve time-consuming and we do not afford to do this, sorry! We only can provide support for basic theme settings.
Notice that all the steps from this guide were tested with the theme and if all of these were properly implemented will work as expected with the theme.
If you are not aware of these steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
Hope this helps!
