Hello
currently the site is not working. A message comes out that “the newspaper Theme License Key is not registered on this website” while it has been correctly registered. Please fix this quickly because you are making me miss visits and I am making a bad impression ..
@alexandros I think you are caching your wordpress site wrong, I don’t know how, maybe it is a good idea to post the url.
If you are using wp supercache or some other plugin, go to your hosting panel and delete his folder under wp-content/plugins, you should be able to access to wp-admin
If you are using cloudflare, put it into developer mode from the dashboard
hope it can help
Hi the solution is semi working for me but not showing any of my featured images on my posts unless i am logged into my dashboard, any ideas??
I reset and it works for a bit and that screen comes back up!!
@kevingrech I had to reset the key (clear cache etc.) three times until it worked for more than some minutes.
Hello
The problem is resolved in online mode but not in offline mode: https://www.colinmaire.net/
I sent you an email and reply beside the plaque.
It is urgent, please help us get back to normal situation
I have the same problem. Resetting key and entry of a new one dowsn’t work due to API server is down.
The changing of ma page and mentioning “pirating” is absolutely outrageous.
This is unprofessional!
This is not the first time this happens, I have suggested in the past to change the warning screen to something like “error databaseconnection” or something like that so it looks like a system faillure but never ever use the “you are a thief” warning for all to see.
