Lightbox images on mobile
Hi, a couple of questions:
1. Is there a posibility to inclide zoom on image when image is opened in a lightbox on mobile? When i double tap on image to zoom in?
2. Background scroll to image position in an article (when I scroll through images in lightbox) doesnt work on mobile. Can it be activated?
3. Finger scroll left-right on mobile doesnt seem to work. Scrolling through lightbox is possible only with slide arrows. Is there a way to activate it?
Hello !
Unfortunately this features are not available at the moment in Newspaper Theme.
We are sorry for the inconvenience!
Ok. Thanks for the response. As a workaround, I’m using a plugin for the lightbox. It’s ok for the images that are not in the gallery but for the gallery, there is a problem similar to this one https://forum.tagdiv.com/topic/tagdiv-composer-generates-lightbox-gallery-how-to-disable/ Tagdiv gallery is automatically generated (tag div lightbox opens beneath the lightbox of the plugin) although the modal image is disabled in the settings. I can’t see any other option for the tagDiv gallery (to disable it completely) in the theme panel.
Unfortunately as our support policy mentions: https://forum.tagdiv.com/newspaper-theme-support/ We cannot provide support for un-tested plugins.
Thank you for understanding!
Hi. I understand. But if I disable the plugin I still get the tagDiv lightbox on galleries. And I also disabled this option “GENERAL MODAL IMAGE”. Is there a waz to completely disable tagDiv gallery?
Hi. Thanks for the effort but it doesn’t solve the problem.
It seems like the tagDiv lightbox is activated always when the image link is set to “media file” or “attachment page”. For the lightbox plugin I want to use, I need one of these options activated. But in the current situation, when I add a gallery inside the post and set it to default (not tagDiv gallery) it still brings up the tagDiv gallery lightbox, for whatever reason. So I end up in 2 lightboxes activated at the same time. Modal image option is disabled and it works fine for the images inside the post (not gallery). But for the galleries it’s different and I still get that tagDiv popup lightbox. Hope I explained it well. And hope there is a way to completely disable tagDiv lightbox from the theme.
Hi!
I have tested it on my end and disabling the general modal image from the theme panel completely disables the lightbox effect.
– admin url and credentials
Our team will take a look!
