Loading speed slow
Is there a limited number of elements we should stick to keep the pagespeed optimal?
The primary factor in page speed is load-efficiency. For example, you could be using relatively few mods and still get a bad page speed score if you aren’t implementing proper pre-load rules, modifications, etc. Alternatively, you could make hundreds of mods and get a 99% page speed score if you optimize it to oblivion. But as a rule of thumb, try not to use more than a few flex-blocks. Also, in TD Composer, hard-coded style mods you make will load slower than the external custom css sheet. So try to make site-wide css changes in the external style sheet so you can optimize it with your caching plugin. If you want to add plugin-based blocks, I’d recommend Genesis and to a lesser degree Advanced Gutenberg.
Hello !
The page speed of your website depends on how well your site is optimized, if you follow the steps which are presented in this tutorial here -> https://tagdiv.com/how-to-increase-page-loading-speed/ you’ll be able to increase the speed of your website.
Also you can check this similar topic for more solutions: -> https://forum.tagdiv.com/topic/optimize-script-to-improve-site-speed/ -> https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
– https://forum.tagdiv.com/topic/a-few-tips-for-newspaper-x-speed-high-cpu-usage-issues/
– https://tagdiv.com/how-to-increase-page-loading-speed/
Please note that page speed is not covered by the support team: https://forum.tagdiv.com/newspaper-theme-support/
For page speed and other services you can contact our custom work team here: https://tagdiv.com/premium-customization-services/
Hope this will help you!
