I am having major issues with the Homepage Post block.
When I add it into Visual Composer, it drops it down so it is the last thing on the page. I have tried everything but nothing seems to work.
You can see the issue here:
http://www.cgmagonline.com/homepage-style2/
I’ve checked your site and noticed that the html structure of the page is affected, that’s why the elements are not displayed correct. If you made some changes in theme files try to revert them, also remove any custom code added in theme ads spots, row html, row js if you’re using, deactivate all plugins except Visual Composer, clear all caches and test again.
Inspecting your website with browser’s developer tool I’ve noticed that a few containers are not displayed correct: http://screencast.com/t/td4hJoSr – http://screencast.com/t/JyKDWbfY1k Please make sure you followed the above instructions and if you still have this issues do a clean update, meaning the we recommend to delete the old theme files, including the plugins from theme’s path, clear all caches, deactivate all others plugins that you have it installed, purge cdn files then follow our documentation in order to install the theme again: https://forum.tagdiv.com/install-via-ftp/ – https://forum.tagdiv.com/install-via-wordpress/
