I use Hardypress for almost all my WordPress work because nearly all my clients do not require the functionality of a “live” WordPress installation. Hardypress is really fast and, most importantly, very secure without needing ongoing maintenance.
The only issue is that I am not able to change the Memory Limit, Execution Time and Max Values.
The values are
Memory 40mb
Execution time 30
Max Values 1000
My question is this…IF TagDiv Newspaper is only being used by Admin to build, create and edit pages and posts but the actual published site is served as Static HTML files, are there any issues that I am likely to experience with these values?
Usually, those settings are to make the theme to work better, also WP Memory Limit can be set in wp-config.php file and this will help a lot, this is use for cloud library.
