menu problem
I cannot edit/add new menu, after pressing save button, homepage appears 🙁
http://www.mojatransformacja.net/wp-admin/nav-menus.php?action=edit&menu=20
  • This topic was modified 9 years by alicjusia.
Hello alicjusia,
Check your system status parameters to be according to our documentation and then, try to check your backend and see how it’s work.
hi, thanks, system detected no cache plugin, after install it unfortunately the same, save button redirects to homepage
Hello alicjusia,
My advice is to make a full backup to your data and then make a new clean install from scratch via FTP way with the latest version of the theme, without using any untested plugins and check the results.
is this the only solution? is this theme, or wordpress?
The theme needs these parameters to be adjusted if needed – https://forum.tagdiv.com/system-status-parameters-guide/ because this could be the cause for your problem. Please check this and try again to see if the menu issue is still present. Let us know how it goes.
Thank you for understanding!
all settings are fine
If you still are experiencing problems with the menu, maybe a plugin could be interfering with this process. Try disabling all your plugins except Visual composer, clear the cache and try to see if the issue is still present. If it is you can try as suggested a theme reinstall – https://forum.tagdiv.com/install-via-ftp/ – https://forum.tagdiv.com/install-via-wordpress/ with the latest version and also use only the plugins bundled with the theme package to test this. Also make sure you have the latest version of WordPress installed.
