Mobile Pages showing "No mobile content!" Article posts work fine
Okay, this is weird. But when on mobile, pages are not showing up properly when you click on them in the navigational menu.
When you go to a page, it says, “No mobile content! – Edit mobile content”
Homepage works fine. Article posts work fine. Only pages that are not the homepage are having this issue. Anyone have an idea how to fix this?
If you use Mobile theme plugin, then you can not edit the pages with TagDiv Composer.
You have only some settings for this layout, which you can find in Theme panel -> Mobile Theme. Please note that if a page is made by Composer, than the content won’t be displayed on Mobile theme version. You should create the content with the Mobile Editor.
For more details, please take a look here:
– https://forum.tagdiv.com/mobile-theme-introduction/
– https://forum.tagdiv.com/the-mobile-theme/
You can edit the mobile pages like this and create your own design: https://www.screencast.com/t/mCDwGFln
Hope that helps you!
