Mobile Speed is very Slow
Hey,
My website’s mobile speed is very slow with both Tagdiv AMP version and on the simple mobile theme. Also on homepage, posts, and pages the speed is very slow. Atleast I need fast speed for posts. I am using WP-Super-Cache plugin.
I also followed https://forum.tagdiv.com/topic/how-to-increase-website-performance/
please help me out to solve the issue.
how to increase the speed as Google announced the new algorithms that, Mobile Speed must be increased.
If this is your website, there are some mixed content issues at first sight
– https://www.screencast.com/t/1Wx8Ujhvn3lB
They are referring to some fonts you are using on the website and could influence loading speed.
Also plugins may slow down the website, try as a quick test to deactivate theme all, leave only theme plugins active, check before and after loading speed.
I see you have both page builders active, that would have a large impact on loading speed. Deactivate the one you don’t use. We recommend that users use the tagDiv composer, we constantly try to optimize this builder. Try as a test to deactivate WPBakery, check the results.
Install a caching plugin or use free Cloudflare. We recommend WP super cache as a caching plugin
Or use Cloudflare with these settings
after disabling WPBakery, site not loads, it shows error 500
Contact your hosting, see if they can identify what is causing such a problem, maybe check error logs. Deactivating a plugin, in this case the WPBakery, should not cause website crashes or internal server errors. This would mean there is a level of instability in the website or server.
