( https://prnt.sc/11s0bty ) this is the correct form that should appear but it is appearing like this in all mobiles: ( https://prnt.sc/11s0dls ) it’s not the way I left it in the newspaper.
1 https://prnt.sc/11s0p2d
2 https://prnt.sc/11s0pqc
3 https://prnt.sc/11s0qe6
4 https://prnt.sc/11s0opq
If in my tagDiv Composer settings are correct, why on mobile phones the layout format does not remain as I left it ??
From what you describe it seems you have installed Mobile theme plugin. If you created the mobile pages with TagDiv Composer, then when you install Mobile Theme plugin, your pages will be overwritten by the plugin.
The Mobile Theme is a performance optimized theme included in the Newspaper main theme and it loads only for mobile devices. It comes with its own templates for page, post, category, etc so your current templates from the desktop theme will get converted to the mobile theme layout. For more details, please take a look here: https://forum.tagdiv.com/the-mobile-theme/
Better deactivate the plugin and see the results which you already did because I checked your website and it seems all is alright at the moment.
I deactivated the file, now everything is fine. Any other problem I will report here. Thank you so much.
I disabled the mobile tagdiv plugin, and now the images have disappeared from the posts, how do you make them appear?
I checked your website and it seems all pictures are displaying just well.
Please delete your cache(also from your browser) and try again.
We recommend using WP Super Cache plugin https://forum.tagdiv.com/cache-plugin-install-and-configure/
