Hi.
I would like to disable the mobile theme on certain pages, is this possible?
Because Buddypress pages do not load in the mobile version of the theme.
DESKTOP VERSION https://ibb.co/zRTMnsS
MOBILE VERSION https://ibb.co/BGh3yBx
MOBILE VERSION FROM DESKTOP https://ibb.co/VS18w0f
thanks in advance, regards.
Yes. Check this thread and make sure you set up the page in the mobile editor as explained here: https://forum.tagdiv.com/topic/issues-with-buddypress-in-mobile-theme/. We have 3 options available for mobile versions that you can use:
1. Responsive version: A responsive version of your website looks similar to the desktop version. TagDiv Composer is used to edit the page. Click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB. You can see your mobile version there and edit or adjust the elements to look better.
2. Mobile pages: https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages
3. Mobile theme plugin: The Mobile Theme is a performance-optimized theme included in the main Newspaper theme that only loads on mobile devices. It comes with its own templates and designs for pages, posts, categories, etc., so your current templates from the desktop theme will get converted to the mobile theme layout. Please see https://forum.tagdiv.com/the-mobile-theme/ and https://forum.tagdiv.com/mobile-theme-introduction/ for more information.
A full explanation is here: https://www.youtube.com/watch?v=SpGkOnJeNZY
If you need to use mobile version 1 or 2, then you need to uninstall the Mobile Theme plugin and AMP.
Thanks! The option to disable the mobile theme (https://i.imgur.com/42Bj2XY.png) is the one that best suits what I require, everything works correctly now.
Regards!
