Mobile Theme > Post Settings, Customize Mobile Theme + AMP
Dear Support,
Is it correct that I do not have options Mobile Themes > Post Settings
like on image in Documetnation about Mobile Theme, url:
https://forum.tagdiv.com/wp-content/uploads/2021/09/mobile-theme-amp-settings.png
Post Settings is in Theme Panel Layout Settings
Our site url: https://nook.rs
Is it possible customize the Mobile Theme + AMP?
How to remove button ToTop in Mobile Theme?
Hoe to delete Autors before date in our Home Page in Mobile version of our site?
I disabled the button on mobile devices, but button is still exist..
Thank you in advance.
Hello @platamun47 !
We have 3 options for mobile versions that you can use:
1. Responsive version: A responsive version of your website looks similar to the desktop version. TagDiv Composer is used to edit the page. Click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB. There, you can see your mobile version and edit or adjust the elements to look better.
2. Mobile pages: https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages
3. Mobile theme plugin: The Mobile Theme is a performance-optimized theme included in the main Newspaper theme that only loads on mobile devices. It comes with its own templates and designs for pages, posts, categories, etc., so your current templates from the desktop theme will get converted to the mobile theme layout. Please see https://forum.tagdiv.com/the-mobile-theme/ and https://forum.tagdiv.com/mobile-theme-introduction/ for more information.
A full explanation is here: https://www.youtube.com/watch?v=SpGkOnJeNZY
Make sure you do not use Mobile theme plugin, if you use the mobile option 1 or 2.
Dear Bettina,
Thank a lot!
Best Regards
platamun47
Dear Bettina,
is it possible to use my create mobile pages with wordpress AMP plugin.
I tried implement this, but after scan site with AMP plugin I have a issues.
AMP plugin: https://wordpress.org/plugins/amp/
Hello @platamun47 !
No. The AMP only works better with the Mobile Theme plugin.
From my point of view, if you don’t use the Mobile Theme plugin, then there is no reason or benefit to AMP.
Dear Betina,
I understand.
Just one this.
Customize or change Mobile Theme layout is not possible.
Am I right?
Hello @platamun47 !
You can’t customize the Mobile theme with the TagDiv Composer. There are some settings that are only in the theme panel(see documentation).
