MOBILE THEME PROBLEMS
I am trying to run campaign for my site using mobile theme/AMP. However everyone clicking on ad fb, disappear immediately as the frontpage is only blog and not showing shop. How can I feature shop on homepage? I bought 4 pcs of your theme due to shop and fast AMP.
Maria
Hello Maria!
Please provide more information(screenshots/video) about what exactly you need to achieve or what is the issue there and your website link.
there is no use sending you link on that. As I hope you know as you are the creator of the mobile theme, the homepage in mobile theme for newspaper is only showing articles. I want to add products from the woocommerce shop on the homepage. How much more clear can this be explained?
Maria
Hello Maria!
Unfortunately, the Mobile theme is not working like that.
We have 3 options for mobile versions that you can use:
1. Responsive version: A responsive version of your website looks similar to the desktop version. TagDiv Composer is used to edit the page.Click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB. There, you can see your mobile version and edit or adjust the elements to look better.
2. Mobile pages: https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages
3. Mobile theme plugin: The Mobile Theme is a performance-optimized theme included in the main Newspaper theme that only loads on mobile devices. It comes with its own templates and designs for pages, posts, categories, etc., so your current templates from the desktop theme will get converted to the mobile theme layout. Please see https://forum.tagdiv.com/the-mobile-theme/ and https://forum.tagdiv.com/mobile-theme-introduction/ for more information.
A full explanation is here: https://www.youtube.com/watch?v=SpGkOnJeNZY
If you need to use the mobile version 1 or 2, then you need to uninstall the Mobile Theme plugin.
In that case it means i would have been better off choosing a different theme and not Newspaper…that was very bad when my goal was a shop and amp including using desktop theme
Maria
