Mobli website not work help me
https://www.tamilpriyam.com Mobile Theme not work.
Do you have installed the Mobile Theme plugin? Clear all the caches, purge CDN files and check the results. If the problem is still there, please let us know. For more details about our mobile theme functionality, please check here -> https://forum.tagdiv.com/the-mobile-theme/
I have done everything but it does not work yet. can you help me
i can giv admin info
Hi Arul,
I have checked your website and I saw that your Mobile Theme works as expected, as you can see here -> https://www.screencast.com/t/HDwpowpIT Also, please check the AMP settings to be according to our documentation from here -> https://tagdiv.com/amp-newspaper-theme/
The tagDiv Mobile Theme now works best with the AMP plugin to provide a complete solution for your content on mobiles. You can find out more here.
https://www.screencast.com/users/tamilpriyam/folders/Default/media/c345fc9d-fd29-4a72-97f0-63c04d60e99b
https://www.screencast.com/users/tamilpriyam/folders/Default/media/41f934c3-7263-4d6b-85b0-6c6c6af9590d
hi mobile pages work partially. I guess it should be all right. I did everything about AMP settings to be according to our documentation. but it does not work, I do not see CATEGORY, first page news, could see last news
I have checked your website, the AMP seems to works as expected but on mobile, on your homepage, you get that white space because you do not have set up any Featured posts, sorry! Using the mobile theme, you need to add some posts inside the Featured Category, because this is the mobile theme default functionality. Also, check your AMP ads configuration because it seems that are not correctly displayed at your website.
can you help me. I’m not fixing
Hi Arul,
In that case, you should not make an overwrite to your old files sorry! You need to completely remove your old folder and add it the new one. You need to make a clean install from scratch to achieve good theme results. Please check the B section from here -> https://forum.tagdiv.com/how-to-update-the-theme-2/ and strictly follow the steps from there if you want to achieve better theme results.
