model does not match the content – Medicine PRO
I have just installed the theme on a blank wp instance and installed the demo “medicine pro” as well.
As soon as I open the file “Category Template – Medicine PRO” in the cloud templates I get the error:
Errors at columns elements: 3(models) : 4(dom). The model does not match the content Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)
How I can fix it?
Make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv plugins, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
When tagDiv Composer is not working ->https://forum.tagdiv.com/tagdiv-composer-not-working/
Let me know the results!
Hi Calin,
all settings are like in your requirements, but was still not working.
I tried again to create it new from templates, now it’s working
Is possible that the old template to be corrupted, maybe something was not correctly imported or something.
If there is still a problem, let us know!
