Navigation Not showing in mobile screens
I am facing one issue that is, while AMP Enabled in post that time navigation is not showing in mobile device.
Can you please help me out.
Thank in Advance
Hello !
Please provide a link to your website in order to inspect.
Thanks for replying.
https://www.youropinioncorner.com/category/business/
here is the link.
For now, I have disabled AMP in all posts but you can check the issue in category pages.
Thank you
Hi anishdesai2003,
Please use the amp plugin with the mobile theme plugin as in our documentations from here :
-> https://forum.tagdiv.com/the-mobile-theme/
-> https://forum.tagdiv.com/tagdiv-amp-plugin-tutorial/
Also you can use the settings from theme panel, these will be apply for amp and mobile theme too -> https://i.imgur.com/6QXJvFR.png -> https://i.imgur.com/mi0qdQf.png
Let me know if the problem persist!
Hi Calin,
I had installed the AMP plugin and done setting as per your Docs. But in that case Navigation is not showing in all pages except Home page.
Thank you
Using the amp wit mobile them it should be look as in our live demos from here -> https://demo.tagdiv.com/newspaper_local_news/
Please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv Composer, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Let me know the results!
