Need help adding Company name to "Sample Field Data" on Job Hunt pro Jobs Page
I am working on a site with Job hunt pro design template.
https://musicuncle.com/jobs/
trying to figure out how to get the job company name here inside the green circle – https://ibb.co/f8v5bDm
While clicking on edit template on the page i can access this page.
https://ibb.co/gtWY8V6
Changing the custom field name – td_source_title_with_url to the custom value i created isn’t working.
I added a custom field to jobs menu called workplace – https://ibb.co/xSCpYqn but changing custom field name from “td_source_title_with_url” to newly created field doesn’t help
How can this be fixed?
The jobs tab page on company page doesn’t show the job either, what will be the best practice to fix it – https://imgur.com/a/gfTXw2Y
My taxonomy, Posts and Field Groups in ACF – https://imgur.com/a/yuLdoIc
Hello @abhishekpandaay!
You should be able to change the name of your CPTs in the CPT/UI plugin or ACF plugin.
Normally, that custom field should be completed when you edit the CPT (Gutenberg).
If you change the name of that custom field, then you need to edit the module template and change the name from there too. You can simply leave it as it was and just add the value for the custom field in Gutenberg.
Every CPT demo has a plugin with the same name that imports the CPTs used in that demo.
Check out our documentation:
– https://forum.tagdiv.com/introduction-cpt-acf-newspaper-theme/
– https://forum.tagdiv.com/custom-post-type-support/
Edit every page and replace the names of your taxonomies, CPTs, and custom fields.
Hello Bettina,
Thank you
I’ll look into it.
Can you also suggest which module it is from where this data (the company name on job listings on jobs page) is pulled as I’ve been trying since 5 hours but couldn’t find?.
You should edit the module templates in the demo’s plugin file.
In the cloud templates -> Modules, you can see all the modules you use and their names.
For every module template, there is a PHP file in the demo’s plugin folder.
