Over a few weeks ago, I added an adsense code for the 728×90 ad.
I made sure the code was set to horizontal on my adsense account.
I went to the theme panel, clicked on Ads, then pasted the code on Smart list 6.
Ever since then, the ad never shows up.
Please help me to resolve this as it is frustrating. I don’t know who else to turn to.
I have the same problem too. Ads dont show up. Upper and inline adsense ads.
Hi john432 and sultanmehmet01,
Make sure that your ads are approved, also please provide some links where should be display the ads to can inspect the situation and some screenshot withe the settings you’ve made for the ad code, in this way I will be able to help you!
what do you mean if my ads are approved? I’m using adsense. They don’t need to be approved.
Please see attached file for where I placed the ad code.
Please copy and paste the link below:
Hi john432,
This C:\Users\DELL\Desktop\theme_panel.png is a path from your desktop to a png image, this is not an adsense, if you want to use banners (images) please check our video tutorial from here -> https://www.youtube.com/watch?v=biTpVVlr8j8 also please check our documentation for ads -> https://i.imgur.com/XauGxoN.png -> https://forum.tagdiv.com/ads-adsense-overview/
Also you can check this article about How AdSense works -> https://support.google.com/adsense/answer/6242051?hl=en
If there is still a problem, please provide me a link to your website where I can inspect the problem.
check it out for yourself. Go to theme panel, click on ‘ADS’, then click on smart list 6. My adsense code is pasted there.
This is my WP dashboard login: https://www.fightnailfungus.net/wp-login.php
here are my details:
username:
password:
This reply was modified 6 years by
Calin.
Please do not post your private credentials on the forum.
Yes, you have set an adsense code in smart list 6 -> https://i.imgur.com/K3ZkA2f.png but, this will not be display because you do not have apply on any posts the smart list 6 -> https://i.imgur.com/jwH4hd1.png -> https://i.imgur.com/1SNq2zb.png -> https://i.imgur.com/orOO3nO.png in order to display that ad on smart list 6 you need to make a smart list -> Smart list ads or you can set the code in a different ad spot, for example -> https://i.imgur.com/PlPFSkf.png results -> https://i.imgur.com/mupFdsH.png
Hope this will help you!
You’re right, I forgot this was a public forum. Thanks for deleting my credentials.
I didn’t know that for the Smart list placements.
thanks for providing me with samples with attached documents. I will try these.
I will notify you if I run into any problems.
john432.
In pages you need to set the ads using tagDiv Composer, you need to set the code in ad box -> https://i.imgur.com/jxhwcit.png -> https://i.imgur.com/AjCLs77.png -> https://i.imgur.com/UbJs8DB.png -> https://i.imgur.com/3Zg8Fk2.png
I added the code for the article top ad. The ad isn’t showing at all.
article top ad code
where is the article top ad???
I selected Smart list 6 for every post on my WP dashboard and it still has shown ads on any of my posts.
I pasted the code
smart list 6 selected
ads not shown
Hi john432,
I think you didn’t understand how the smart list works or maybe you didn’t check our documentation for it.
Let’s try one more time, in order to set the ads in smart lists, you need to make a content for smart list and to select this template, as I can see in your screenshot you only choose the smart template.
Write your Smart List Content – the post content must have a certain structure:
Title (use h3 tag)
Description
Smart list ads -> https://forum.tagdiv.com/smart-list-ads-newsmag/
Also if the ads are still not displaying, please deactivate all non them plugins, and check again, the ads should be display in article top, also make sure that you are using the latest version of Newsmag, v4.9.3 -> https://tagdiv.com/update-newspaper-theme/
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel. We will take a look. Include a link to this topic in the email.
Let me know the results!
