In category template here https://img.onl/FGN43u the Posts Loop 2 element is used. we really like this one.
Right now both ad boxes get their banner code from a single Ad edit box, meaning its showing the same ad banner on the red circled positions. How we can keep this layout as it is but have a different banner on the second ad position?
One scenario we tried was to duplicate the Posts Loop 2 element, limit the posts to 6 on each (instead of 12) and then we can edit each ad respectively. but our issue with this scenario was that both Post Loop 2 elements are showing same posts, the second one doesnt display the next ones from latest.
Any ideas how to get 2 different banners in there? 🙂
Thank you very much
We do not recommend setting two posts loop on the same page/template, because most of the settings from the first loop element will be set for the second one.
A workaround is to use flex blocks, and set the ads after each flex block and using the offset option -> https://forum.tagdiv.com/offset-feature/
thank you for the workaround, will test it soon.
We need also one more thing to be fixed, the duplicate license key.
We used the key another domain and now we need to assign the NEW key on this site. i also emailed you about it. can we fix this asap since we are unable to complete the site to launch today.
not quite sure how the logic works with licenses.
the domain of the other website is shown as ACTIVE. the current domain seems inactive but as i said, no option to EDIT the license key. i just have a button option for assign/ unassign. No option to insert a new key
This reply was modified 2 years by
oqt.
Reset the license key from that website: https://www.screencast.com/t/Zt12bpyX
and activate with the new license.
