I have just bought a theme from you and I am having some problem with it.
As it were.
# 1. Have tried to insert edit with TD composer several times but have found it.
My humble request to you please use my username or password and install ” edit with TD composer”
# 2. Dear please activate weather option. I have started the weather option given in the theme But in that every city only shows the temperature of that city Whichever name we put on it, fix this problem.
# 3. All the features Image of my previous theme are still showing good. But when I create features Image on this theme they do not show properly. Even when we have the same size as the previous image.
Please note I have already sent an email for these problems with https://www.placementstore.com/wp-admin Username or Password.
My Website URL: https://www.placementstore.com/
We will try to help you with the problems you are having.
1. Don’t know what exactly you want to insert. Once installed and active the option to edit pages with the tagDiv composer will appear in many places
– https://www.screencast.com/t/YlNOVF86vq5w
– https://www.screencast.com/t/zJKN2fCS267e
– https://www.screencast.com/t/UYKSKp24zST
2. The weather widget works properly if you configure it as specified here
– https://forum.tagdiv.com/weather-widget/
– https://www.screencast.com/t/0PKq7X7tygs
I have checked top bar and widget and they are both working. Try changing the API key and make sure you use valid locations.
3. If you could provide some more details about what exactly is the problem it would be helpful. For the posts I inspected I see that you use post template 5, this template does not display the featured image in the post page
– https://forum.tagdiv.com/post-templates-2/
The thumbnails that are created seem to not be created properly
– https://www.screencast.com/t/cO2cr4Xd88
The module you are using for the blog page uses this thumbnail
– https://www.screencast.com/t/bEmz1toX5Vx
Please regenerate the thumbnails using this guide, this should re-create all the thumbs
– https://forum.tagdiv.com/search/regenerate/
