newspaper cpu problem
Hello
I have an issue with newpaper theme. I activated this theme and im just using 5 plugins.
-tagdiv composer
-tagdiv social
-akismet
-yoast
-Super cache
i tried diffrent cache plugins. cuper cache,w3 total,fast cache,litespeed all of them. i tried one by one. also im using cloudflare for cache.
But my website cpu usage is too high.
can you help me please ?
Please make sure that you set the cloudflare link in our tutorial -> https://forum.tagdiv.com/cloudflare-cdn/ also we recommend WP Super Cache as plugin cache.
Also in this topic was some similar problems, please check it here: -> https://forum.tagdiv.com/topic/my-website-is-using-full-hosting-resources/
Thank you for your understanding
Hello Calin,
Are you kidding me ? You answer without reading what I wrote!…You want me to repeat the solutions I’ve tried.
I’ve already tried them but my problem continues.Looking forward to a real help urgently
Regards
Did you check the configuration for cloudflare ?
Also please note that only tagdiv composer and tagdiv social counter are theme plugins, the akismet, yoast, super cache are not theme plugins, make a test deactivate them and see if the cpu is the same, also please not that WordPress and Newspaper theme need some cpu resource, also all plugins that you have need cpu and memory resource.
-> https://www.screencast.com/t/jf1gXKbmia -> https://codex.wordpress.org/High_Traffic_Tips_For_WordPress
HOW TO REDUCE WORDPRESS CPU USAGE ->https://wpfixit.com/reduce-wordpress-cpu-usage/
I don’t know how to tell more differently.
There is no plugin running on my website, there is no problem with other wp in the hosting company, there is no additional traffic to my website.
My website has not been working properly since I bought this template and I have to deal with the website as much as I did before.
Waiting for the solution! Urgently!
Please take a look and see what process make your cpu usage to be too high;
Please make sure that you have php version 7 also please make sure that the theme system status is configured as mentioned in the requirements guide. Please follow the guide carefully
After you set all requirements please check again the cpu.
I tried all said the same results…We’ve changed the theme then all problems have improved!
Now I’m waiting for a solution to this issue from developer ! Because this subject is completely related theme ,If it doesn’t, I want a refund ( urgently ! )
Please request a full refund, specify this case and we will get your money back. For refund, please complete this -> https://themeforest.net/refund_requests/new
Thanks for your interests in our theme!
