When I use Cloud templates with a Category and add ‘Block 11’, I cannot find the ‘normal pagination’ option in the filter settings -> Extra -> Pagination. How can I add this setting?
thanks
Excuse me , how do I use the posts loop shortcode instead.
I set CATEGORIES -> Per category settings -> Category Cloud Library Template ( use Block11)
Could you give me a sample to do it ?
thanks
If you use a cloud template, you can customize it using the tagdiv Composer and add the element to the page: https://app.screencast.com/EPEu7gQO6h2KJ. But if you use a default template, then you can not edit the page with the tagDiv Composer. We recommend using cloud/PRO templates to have the possibility to edit them with the TagDiv Composer, which contains a lot of functions and features; please check our tutorial here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
More documentation about the cloud templates is here:
– https://forum.tagdiv.com/cloud-library-templates/
– https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
– https://forum.tagdiv.com/cloud-library-category-templates/
About pages here: https://forum.tagdiv.com/page-templates-2/ -> https://forum.tagdiv.com/homepage-how-to-build-and-set-it/
Check out this video about how to create a website from scratch: https://www.youtube.com/watch?v=SoGQ0d5kIBg
Unfortunately, Block 11 doesn’t have this setting. Use the posts loop shortcode instead.
–> May I ask which file I need to modify shortcode?
