In Newspaper 9.1, the tagDiv Composer and tagDiv Social Counter plugins are permanently deactivated.
You have to manually activate them and immediately. Please, if it happened to anyone or is happening, can you please let me know?
Give the solution.
Thank you so much
Please update the theme.
For every update, we always recommend the following:
-> First of all, please make sure you have a backup.
-> Please deactivate all the non-tested plugins with our theme before updating.
-> Update WordPress, PHP, the theme, and plugins to the latest version: https://forum.tagdiv.com/how-to-update-the-theme-2/.
-> Check all these requirements for the theme: https://forum.tagdiv.com/requirements-for-newspaper/
This happens to my site almost every single day! TagDiv Composer suddenly deactivates itself. After this happens only garbage is displayed on the home page (and any other pages created with tagDiv composer).
I didn’t change anything. I didn’t update anything. This just happend from nowhere.
Sometimes it is ok for a cople of days. Then all of a sudden it deactives itself.
I would like to know the root cause of this.
Of course you can say “update everything”, which every software vendor will say if you ever encrounter a problem.
But I am wondering why this happens, if I didn’t change anything
Sometimes, the issue can be from a plugin conflict or a cache issue. That’s why we recommend first deactivating ALL plugins except tagDiv ones; if you are using a cache plugin, deactivate it, clear all cache (also from your browser), and see the results.
