Please Help – Homepage Problem
Please visit my site from Desktop or laptop: https://www.hospitality-school.com/
I am facing 2 major issues in Homepage:
1 – Look at the pagination. There is no content after page 1. I cannot show any blog posts like homepage in other pages.
2- How to Delete Leave a Reply part form the homepage. Can’t remove it.
We recommend to use cloud/PRO templates in order to have the possibility to edit them with the TagDiv Composer which contains a lot of functions and features, please check our tutorial here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
More documentation about the cloud templates is here:
https://forum.tagdiv.com/cloud-library-templates/
https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
https://forum.tagdiv.com/cloud-library-category-templates/
https://forum.tagdiv.com/homepage-how-to-build-and-set-it/
“Column text” and “text with title” elements have a button called “edit content” and if you click on that button, the WP Editor will open, and you can add some text/code/shortcode there. Close the WP Editor from X, save the changes from Composer and view the page to see the changes.
2. Edit it with Gutenberg and uncheck this option: https://app.screencast.com/zVJ9NpoVWbnMg
Choose the default option.
