Polish letters (characters) visible in admin but not in fronted
After last update I have a problem with polish letters caused by plugin tagDiv Standard Pack
after I activate it, proper polish letter coding is gone
I disabled all plugins expect tag div plugins and it looks like tagDiv Standard Pack is causing the problem
i don’t have polish letters in whole website (incorrect coding),
but when I’m logged in, there are proper polish letters (correct coding)
what can I do?
  • This topic was modified 3 years by wydawca.
Hello @wydawca !
The Standard Pack plugin is useful only if you are using the default templates.
But, we recommend you to use cloud/PRO templates in order to have the possibility to edit them with the TagDiv Composer which contains a lot of functions and features, please check our tutorial here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
Documentation here:
https://forum.tagdiv.com/cloud-library-templates/
https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
https://forum.tagdiv.com/cloud-library-category-templates/
If you are using a cache plugin, deactivate it, clear all cache and try again.
