Post and Custom Post types Settings not working
SHOW AUTHOR NAME – Enable or disable, none of the settings are working including Enable or disable for featured image – https://tabloidmedia.co.za/
I checked your website and it seems you have the author name there.
Please note if you use a cloud/PRO template you need to edit that page with TagDiv Composer plugin, click on the element and you can delete it and the changes made in theme panel should reflect on your default posts.
For more information please check the documentation from here:
https://forum.tagdiv.com/custom-post-type-support/
https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
https://forum.tagdiv.com/design-post-pages-using-default-templates/
https://forum.tagdiv.com/featured-image/
