Post edition has disappeared "Post settings"
A week ago, the Post edition has disappeared “Post settings”, so we can not modify the edition of the entries or introduce some concepts: Subtitle, Name of the source, Name of the second source, etc.
I tried to install the latest version of Visual Composer 4.5, but the whole Thema is dismounted.
I have consulted wpbakery and this has been his answer:
“Hi,
The “Post Settings” is not our standard feature. It is most likely added by your theme author to enhance the theme functionality. You can check our standard elements/features by creating an online demo here: https://wpbakery.com/try/
We would suggest you to get in touch with the theme author so he can guide you with the same. Kindly check.”
I’m using your Thema: Theme Name: Newspaper
Version: 4.6.3
Can you help me?
Thanks,
José María
Please make a theme update, or a fresh install with the latest version of newspaper, login on themeforest with you credentials and get it from there with all files and documentation.
That is a very old theme version, an insecure for our times; much has changed since that version. Indeed that would be the thing to note. Once you update the tagDiv composer will be automatically activated. Visual composer elements in pages may not display properly if the tagDiv composer is active. Deactivate it and leave Visual composer (now WP Bakery page builder) active. Update Visual composer and there should be no issues
– https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
This is a guide to update the theme
– https://forum.tagdiv.com/how-to-update-the-theme-2/
It is always recommended to keep the theme used, theme plugins and WordPress up to date. Updates will improve the functionality in many ways.
If you would then want to use the tagDiv composer, all pages will have to be recreated using it. The pages must only contain elements that belong to it.
Be sure to check if there are sufficient resources allocated for a optimal performance
Check the theme system status and if needed ask your hosting provider to increase those parameters.
Le us know if you encounter any issues and we will try to help you as best we can.
