Post Sidebar problem & change url problem
Hi there!
I got 2 problems with this theme.
1) When I add a sidebar, i got this weird message :
Warning: require_once(includes/wp_booster/sidebar.php): failed to open stream: No such file or directory in /home/fashi307/public_html/wp-content/themes/Newspaper/sidebar.php on line 7
Fatal error: require_once(): Failed opening required ‘includes/wp_booster/sidebar.php’ (include_path=’.:/usr/local/php56/pear’) in /home/fashi307/public_html/wp-content/themes/Newspaper/sidebar.php on line 7
And all the pictures on the post goes down.
2) I changed the url of my website from https://www.fashioniseverywhere.com to https://fashioniseverywhere.com
when I do that, and go to the Theme options, I got this message on my console :
XMLHttpRequest cannot load https://fashioniseverywhere.com/wp-admin/admin-ajax.php?td_theme_name=Newspaper&v=7.8.1. No ‘Access-Control-Allow-Origin’ header is present on the requested resource. Origin ‘https://www.fashioniseverywhere.com’ is therefore not allowed access.
I don’t get what it says, but it seems i can’t change my options without fixing it.
When I change a setting, the loading icon stay and doesn’t go.
Please help me on this matter, thanks.
The theme has these requirements – https://forum.tagdiv.com/requirements-for-newspaper/ and modifications to be made according to this guide if it is necessary – https://forum.tagdiv.com/system-status-parameters-guide/
You can try to reinstall the theme using this method – https://forum.tagdiv.com/install-via-ftp/ and use only the plugins provided with the theme package, clear any caching installed and try again.
I see that you have many errors and warnings present on your website
https://www.screencast.com/t/vRGaXW5G4cLn
This indicates that the transition to https was not done properly, please check these few leads that have proved to be useful to other users in this situation
http://www.wpbeginner.com/wp-tutorials/how-to-add-ssl-and-https-in-wordpress/
https://css-tricks.com/moving-to-https-on-wordpress/
https://yoast.com/dev-blog/move-website-https-ssl/
You can also check our forum for some insight on this matter
https://forum.tagdiv.com/topic/moving-to-ssl/
Hi there! thanks for your reply.
So here is the checklist you gave me :
Requirements for Newspaper : got all, CHECK
System status parameters : checked, and everything was set
Install theme via FTP : actually I installed a fresh updated theme before i wrote.
Deactivated all plugins : CHECK
And these errors were still here.
As for the SSL transition : the console errors says that an ad is not working properly and the others are about the fonts that can’t be loaded in https, thanks to this theme settings.
Guys i’m stuck here, do you have any other clue about what causes these 2 errors?
I figured out !
That was my fault actually.
The .htaccess got a line with www. in it
Then one file was missing for the sidebar when i uploaded the theme.
So this is resolved.
