Posts Don't Load; Page Filled With Code
I am having issues with random posts not loading, instead showing a blank page with a lot of code ({“version”:”20211209″,”show_thumbnails”:true,”show_date”:true,”show_context”:true,”layout”:”grid”,”headline”:”Related”,”items”:[{“id”:34554,”url”:”https:\/\/www.) where a post should be. I would show a screenshot, but this forum doesn’t allow image upload. I believed that a cache plugin was causing the issue, especially because the issue would clear after purging the cache and purging Cloudflare’s cache. Therefore, I tried various caching plugins (maybe 4). When the issue persisted, I got rid of all caching plugins and have only Cloudflare. However, there is a post page that is currently just code, and I don’t know how to fix this. Do you have any idea what could be causing the issue?
If the problem doesn’t persists when you are logged it, then it is clearly form a cache or CDN.
What I can suggest is to be sure that all the theme plugins that you need are enabled.
Set the CDN like in our guide from here -> https://forum.tagdiv.com/cloudflare-cdn/ also, if you want to try a cache plugin you can trey the one from our guide -> https://forum.tagdiv.com/cache-plugin-install-and-configure/
I hope this will help you!
Cloudflare already had the recommended settings. I fixed the symptom of the code appearing instead of a post by searching for files and folders marked cache and deleting the ones that were safe to delete. The symptom went away without me purging Cloudflare, so I guess the issue was a cache plugin.
WP Super Cache was the final cache plugin I tried. The issue worsened. I don’t know if WP Super Cache was the cause or if there were traces of W3 Total Cache interfering. Either way, I’m hesitant to try any cache plugin again, because I have so many posts and there’s no way to know which is missing until visitors complain. It’s doing more harm than good. Thanks.
I see, in this case it was definitely a cache and the problem persisted because some cache plugins like litespeed, W3 total cache creates files with cache that are apply even after the cache plugins disabled.
