Posts filtered prevent duplication on home page
Hi i would like to filter my posts to go into a different block tab my homepage is http://vards.net I need to place the three posts with coins into the right side bar block tab that says Bid On These Items. please check this link for the picture illustration: http://vards.net/antiques
Gus
Please open a your homepage with tagDiv Composer, and drag a https://www.screencast.com/t/K1iXmqxA
Or if you are using widgets please check in Appearance
https://www.screencast.com/t/Q4cEoPIW
Hope this will help you.
Hi I am trying to seperate the posts for the side homepage via the Widgets in the filter tab it asks for the Post ID filter? it also mentions to exclude posts from this block add them with ‘-‘ (ex: -7, – 16) where do i find these POST ID`s? it seems they go by numbers followed by , commers. Please direct me.
Gus
Please check your documentation for Filter tab -> https://forum.tagdiv.com/block-settings-tutorial/
https://www.screencast.com/t/n07H6w8E
Here you see the category id
https://www.screencast.com/t/2dD0tieeRLn8
Here you can see the post id
https://www.screencast.com/t/0nZNTJ7j
For widgets
https://www.screencast.com/t/VtS6ZgXodQ
Hi Calin,
sorry but I am still having trouble I have used the widget sidebar on my homepage but i does not go to the right side of the page it just stays a the top. Please see here my hompage: http://vards.net
Gus
Sorry i forgot to add this piont so you understand better on my homepage the block that says Bid On These Coins is in my Widget Sidbar and should go to the right of the page but as you see it stays at the top?.
Gus
Please read our documentation for sidebar carefully -> https://forum.tagdiv.com/sidebars-tutorial/
Hi I was able to get the side bar to show on the right side of the homepage however, under the side bar on hompage named Bid On These Coins, only 2 posts are showing even though i have filtered three Post ID`s in the widgets [tagdive] Block 4, also I would like the heading to show on the hompage articles just like the side bar is showing. Please go to my homepage to see: http://vards.net
Gus
Are you sure that all three post IDs used are valid? I see these IDs are used
https://www.screencast.com/t/pln7roZVEw
The one that is not displayed is the “4053” post, please check if that ID is correct. There would be no reason for the block to not display all three posts if the IDs are valid.
Maybe you meant “4503”, this one – http://vards.net/2018/12/18/queen-victoria-full-gold-sovereign-1879/
For the block header background, you could use this general setting
https://www.screencast.com/t/jW6wLQ1piVK
Set the color you want there.
Hi Simon,
yes you are correct i made a mistake with the ID post number which is working fine now however, the second question I asked in my previous post about the heading not showing was not about the color backgrond which you mention, but i would like the heading to show in bold just like on my hompage the headings in all 3 sidebars are shown in bold like: Queen Victoria Full Gold Sovereign 1879 is in bold, but the other 3 posts in the main page do not show the headings in bold, they only show the paragraph only, for instance if you hover over the first post in main page it should have the header saying : A Beginner`s Guide to Coin Collecting and that is what i want to show in bold the same as the side bar posts. Please check here: http://vards.net
Many Thanks.
Gus
Seems the post title is not even displayed in the latest articles module, the text you are referring to below the thumbnail is the excerpt of the post. The title is missing in that module.
Did you maybe make modifications to module 4 in the theme files? If you did remove theme and check again. If you did not, please send us an email at contact@tagdiv.com and provide admin login so we can take a look. Include a link to this topic in the email.
Hi Simon,
thanks for your input but i have an even worse problem now I cannot even access my website: http://vards.net I have spoke to my webhosting tech they sent me this info: Please check the error log /home/vards/public_html/wp-content/themes/Newspaper/includes/wp_booster/td_util.php on line 1385 also i cannot get into my wordpress not sure what has happend here the website was up and you would of viewed it so you could answer my question would you know what the error log is?
Gus
Website is online now from what I can see. Regarding the issue mentioned before, send us an email as specified and we will take a look to try and identify why the article titles are missing in the latest articles section.
Hello Simon,
I have sent an email Subject: reference ticket N0: #268993
Gus
Hi is their any progress with my last request?
Gus
The email might have ended up in the spam folder for some reason, some emails are detected as spam. That would explain why my colleagues did not see it and begin investigating. We try to answer all emails at least once a day.
Please re-send the email again, enter a link to this topic in the email so we can identify it. Let me know once it is sent.
Hi, I have re-sent it the email subject is: Ticket N0: #268993
Gus
Thank you for your help the problem was in module 4 and now has been fixed.
Gus
Viewing 18 posts - 1 through 18 (of 18 total)
