hello,
http://batrountimes.com/
i am using posts lists element but it is not showing on the frontend website.
and is it possible to use contact form 7 on the website?
thanks,
Please provide more details about your issue. Did you have set a cpt https://i.imgur.com/j55UVXC.png? Also, I can’t access the website https://i.imgur.com/qUtDt1R.png
Yes, you can use it. Please check this guide -> https://forum.tagdiv.com/add-contact-form/
This sounds like a caching issue.You can check if is a plugin conflict by checking only with the theme plugins enabled. But since you say when you are logged was working correctly, then it can also be a cache or object cache https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/.
Please let me know what plugin for the cache you have and the server.
We can take a look at this and investigate why it is not working for you. Contact us via email at contact@tagdiv.com and provide the following:
– admin URL and credentials
– cpanel URL and credentials
– license certificate
