Hello –
We continue to have issues with our Newspaper 8 theme. Currently, posts are not updating or showing. My website is https://www.kvnutalk.com/. Please contact me so we can resolve the issues we continue to have.
Thanks,
Ryan
Hello Ryan,
Please switch to a wp default theme and check if new posts show up in that theme as well. I suspect a caching issue.
Please only use wp super cache and these settings
https://forum.tagdiv.com/cache-plugin-install-and-configure/ and the cdn settings:
https://forum.tagdiv.com/cloudflare-cdn/
Hi Bogdan –
Thanks for your reply. I did as you suggested, installed wp super cache and copied the settings as suggested. I thought it fixed the problem as it updated temporarily, but now it’s not updating again. Can I email you login credentials so you can take a look? OR, do you think I need to pay to update WP Bakery Page Builder? I will email you direct with login credentials so you can take a look. thank you!
I guess I don’t know how to email you direct – I thought I could click on your profile and get your contact info. Let me know if I can send you login credentials. Thanks again!
You can send us an email at contact@tagdiv.com if you have not already, and provide admin login information there. We will take a look. Also paste a link to this topic in the email.
Hi Simion –
Sorry for my slow response, I’ve been out of town for a week. I just emailed you the login credentials and brief explanation of the problems we are having. Thanks for your help!
Ryan
