Problem between web and mobile version
After the last update, we discover a small problem between web (desktop) version of our category page : https://overclocking.com/category/test-articles/ and the mobile version. ( For mobile version we use the mobile theme ).
On the desktop version, everything is correct but on the mobile version, we don’t have all categories displayed, only the first one.
We use “Category siblings” to display all subcategories.
Could you help us please ?
Problem with homepage on mobile phone
Hi, newspaper theme does not display some areas on mobile, logo, menu and other important areas, only displays most recent articles. any solution?
//Solution
Please uninstall the Mobile theme plugin.
We have 3 options available for mobile versions that you can use:
1. Responsive version: A responsive version of your website looks similar to the desktop version. TagDiv Composer is used to edit the page. Click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB. You can see your mobile version there and edit or adjust the elements to look better.
2. Mobile pages: https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages
3. Mobile theme plugin: The Mobile Theme is a performance-optimized theme included in the main Newspaper theme that only loads on mobile devices. It comes with its own templates and designs for pages, posts, categories, etc., so your current templates from the desktop theme will get converted to the mobile theme layout. Please see https://forum.tagdiv.com/the-mobile-theme/ and https://forum.tagdiv.com/mobile-theme-introduction/ for more information.
A full explanation is here: https://www.youtube.com/watch?v=SpGkOnJeNZY
If you need to use mobile version 1 or 2, then you need to uninstall the Mobile Theme plugin and AMP.
We use the mobile theme plugin.
But as you can see, we have a change after the last update and we are not able to display categories list as the desktop page.
Thank you for your help
Please use the Subcategories shortcode or revert to the previous version of the theme.
