Hi; we are having problems with the Directories pro plugin not working correctly with this theme. If I enter a category it doesn’t filter and shows all the entries when it should only show the selected category. I have changed the theme and it works correctly so the plugin provider tells me that it is a problem with this theme.
For example, this url only has to show one entry and it does it correctly on a computer but if we enter with the mobile it shows all the entries of all the categories:
https://manilva.ws/empresas/joyeria/
Yes, the same piece of code. If I change the theme it works correctly:
Screenshot: https://ibb.co/19XszmP
Hello; I have found a half solution: If I activate the AMP option it works correctly for me. Can I put this option only for some pages? Can you give me any clue as to where the problem might be?
Screenshot:: https://ibb.co/tm7FDR1
The mobile editor comes from the mobile theme plugin and AMP.
If you use cloud templates, then you can use an element as column text, raw HTML, or raw CSS to add codes.
You should use the mobile theme + AMP and add the code to the post you need in the mobile editor field.
Actually, we have 3 options for mobile versions that you can use:
1. Responsive version: A responsive version of your website looks similar to the desktop version. TagDiv Composer is used to edit the page.Click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB. There, you can see your mobile version and edit or adjust the elements to look better.
2. Mobile pages: https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages
3. Mobile theme plugin: The Mobile Theme is a performance-optimized theme included in the main Newspaper theme that only loads on mobile devices. It comes with its own templates and designs for pages, posts, categories, etc., so your current templates from the desktop theme will get converted to the mobile theme layout. Please see https://forum.tagdiv.com/the-mobile-theme/ and https://forum.tagdiv.com/mobile-theme-introduction/ for more information.
A full explanation is here: https://www.youtube.com/watch?v=SpGkOnJeNZY
If you need to use the mobile version 1 or 2, then you need to uninstall the Mobile Theme plugin and AMP.
