Problem editing theme with "td-composer"
Greetings,
as per screenshot attached when I try to update my site via “td-composer” builder in console it prints me the errors you see.
Link screenshot: https://tinypic.host/i/screenshot-22.W7jY2
Through the builder it is not possible for me to do anything as it is blocked.
In the home page of the site some sections have disappeared showing part of the “td-composer” shortcode. Here is an example:
“[vc_separator style =” dotted ”color =” # 0a0a0a ”tdc_css =” eyJhbGwiOnsicLS ”
I don’t know if the problem may be due to the latest theme update.
You can help me?
A thousand thanks.
Hi PMIComunicare ,
The console display an error that is related forbidden access -> https://i.imgur.com/taNfKxn.png this can be caused by an extra plugin that it is used, by some settings from host or from a custom code that is set n htaccess file .
Please check our guides from here:
-> https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
-> https://forum.tagdiv.com/tagdiv-composer-not-working/
About the shortcode, please be sure that you didn’t edit the page and remove a part of code. If you want you can try a page revision -> https://wordpress.com/support/editors/page-post-revisions/
I hope this will help you!
