Problem preview articles dimension
Hi, as you will see in the images in attach, i wold like to set dimension of preview box of posts on home page at the same dimension like in demo preview. To see open this link https://imgur.com/a/Vn51JlT
Please make sure that you have a featured image set and is to show.
please try to explain better, i want that the dimension of the box is the same for all the article in mansonery as i show you in the pictures. It’s urgent and i’m asking for this for a long time. I wait for a solution.
Please provide a video with your settings on the blocks.
do you understand my request???
This is the video that explain what i’m asking for.
Problem is different heigths of the preview posts on home page.
ITS URGENT IF YOU DON’T UNDERSTAND I WANT TO TALK TO SOMEONELSE.
This will adapt after the length of elements that are show (category, post title, author, date …).
In order to make them to look the same size, you’ll need to set an excerpt on title and post content like this -> https://i.imgur.com/o8UQm5B.png
Big Grid Flex Settings -> https://forum.tagdiv.com/big-grid-flex-settings/
Also you can set the excerpt on words or letters from theme panel -> https://i.imgur.com/c7Q8ckX.png
Here is a similar topic -> https://forum.tagdiv.com/topic/flex-block-1-and-same-blocks-height/
Hi i’m using all the tips you gave to me, but unfortunately is not working.
this is the video after i change my settings as you told me.
Is it possible give my credential in a private message?
It’s still urgent…
  • This reply was modified 3 years by Opes.
Yes, I can take a look at it; for this please contact us via email at contact@tagdiv.com and please provide wp-admin access and the link to this topic to identify you.
I just sent an email with credential and link of post.
Thank you
as you will see on tagdiv composer opening an article everything is ok(video tag div composer).
Opening the same article on mobile that is what i see(on mobile)
I just sent to Anamaria my credential by mail if you need to enter and check. Actually there is mainteining mode on whit lightstar plugin under settings.
Thank you
I will investigate via email.
