Problem updating tagDiv Composer
Good afternoon! After I updated the tagDiv Composer plugin and turned it on, I have a server load and the site is down
https://i.imgur.com/95NU2Ng.png
on the main page constantly online 100-200 people
how to solve this problem? the caching plugin does not help
So before updating the theme and composer there was no problem, and after the update there is an overload. That should not be, if anything it would be better since we removed an additional plugin (multi-purpose) and included it’s features in the tagDiv composer.
Maybe this is a server limitation, please check the theme system status
Check if the same thing happens if you only have theme plugins active, with no theme modifications made.
https://i.imgur.com/plRLzHk.png
use wp rocket cache. I tried to put WP Super Cache but it did not help
tagDiv Composer not active:
https://i.imgur.com/WhjnR1S.png
tagDiv Composer active 1 min:
https://i.imgur.com/vQ8dAzq.png
website https://apkgamezone.com/
Try to re-install the latest theme by FTP
– https://forum.tagdiv.com/how-to-update-the-theme-2/
Remove and delete the composer, install it again from the theme plugins panel
– https://www.screencast.com/t/MAtStP1KDdH1
Increase the memory more if possible, that could be insufficient. Clear the cache and purge CDN files if you use it. Let us know.
I updated js_composer.zip and the main page worked even without the activated tagDiv Composer.
tagDiv Composer does not need to be activated?
WPBakery Page Builder works fine, and with tagDiv Composer loads the server 100%
You must have had the WPBakery page builder active as well, if none of the composers are active, only shortcodes will be displayed. The theme blocks and grids will be displayed by either tagDiv composer and WPBakery page builder.
This problem you are having is most unusual, the tagDiv composer is faster than the WPBakery page builder, so if this is not a hosting limitation then the results should be accordingly. Can you check what processes are consuming all these resources?
If you can, please install make a copy of the website on a sub-domain and install the latest theme version there. Check if the same thing happens. Use the duplicator plugin for example.
