Problem with adding ellement
I have problem to add shortcode to element text with title. When i open it and i click edit content and than click text i can import nothing becouse this window doesnt open.
The first thing to check would be the theme requirements, system status section
It is imperative that the parameters mentioned in the guide are configured properly. Insufficient resources can cause many issues with the theme or the plugins, if needed ask your hosting provider to increase them as specified.
If there is no need for modifications in that matter, in some cases the solutions from these topics worked for blank or grey pages and other composer problems, you could give them a try if possible
– https://forum.tagdiv.com/topic/gray-page-tagdiv/
– https://forum.tagdiv.com/topic/javascript-error-td-composer-wont-load/
Let us know if there still is a problem, or if you fixed the problem.
